01-09-2008, 10:42 PM | #1 |
Help me tune my bike
So my bike runs good, except it wont idle well. once it is warmed up it will but I cant get it to idle on startup. I have moved the clip all the way down on the needle, and have messed with the idle screw and still no luck. It is still lean I think, definitely not rich. So I saw in the other thread this adjsutment screw.
http://www.chinariders.net/gallery2/...g2_itemId=1092 does this help with idle? |
01-09-2008, 11:10 PM | #2 |
I'm a newby too, but I have been messing with that screw a lot today so I'll comment. I'm told that is the fuel mixture screw and it did help a little with my idle. Mine fires right up first time with not choke since I backed that screw out about 4 turns. Others only do it about 1-2 turns. Backing it out should help richen your mixture I think. It sure helped me today since I put on my new cone filter and drilled out the exhaust. Good luck to ya.
01-09-2008, 11:36 PM | #3 |
thanks for your help
01-10-2008, 09:28 AM | #4 |
That screw is the mixture screw. There should be screw up on the right side of the carb about in the middle that adjust the idle.
Allen
