Thread Tools Display Modes
Old 07-24-2024, 06:55 PM   #1
FADEDSLUMPGOD22   FADEDSLUMPGOD22 is offline
Exclamation Lifan Xpect supermoto
New member, and not sure where to ask this. Does anyone know if a crf230 supermoto kit will work with the Xpect? Or an xt225 kit? I really want supermoto wheels on my xpect since I'm 95% street use but have no idea how to go about it. Im curious if a 17x3.5 front and 17x4.25 rear would fit since my front tire is 90/90-19 and rear is 110/90-17.
Old 07-24-2024, 07:41 PM   #2
dirtbkr188   dirtbkr188 is online now
dirtbkr188's Avatar
Using the tire width sizes on the bike, those 17's should work for you
Old 07-24-2024, 09:23 PM   #3
Okay thanks for the reply, would you happen to know the axle diameter on these Chinese bikes?
Old 07-24-2024, 10:41 PM   #4
UPDATE:: there is a guy in the Phillipines that build supermoto wheels for Honda Xr150L which has identical stock tire size as the Lifan Xpect...still don't know if the axles are the same size as the xr150l but if so then it's a direct fitment for the xr150l wheels on the Xpect. If so the supermoto wheels would be sized as 17x3 Front and 17x4.25 Rear with the recommended tire size being 100/80-17 front and 140/60-17 Rear for that nice wide tire look.
Old 07-24-2024, 10:47 PM   #5
dirtbkr188's Avatar
No, I do not...sorry
Old 07-24-2024, 11:32 PM   #6
Aussie_in_MO   Aussie_in_MO is offline
Since you've got the Xpect already then turn some wrenches, pull the axles and take some measurements
2023 Templar X
2009 Triumph Bonneville
1976 Yamaha DT175
1974 Honda MT125
Old 07-25-2024, 12:54 AM   #7
I'm away from home for awhile so not possible for me to measure my axle diameter at the moment. I planned to put calipers to the axle once I return home but I figured someone out there may know the measurement.
lifan, supermoto, xpect
