Old 06-13-2024, 12:45 AM   #1
CliffLamb   CliffLamb is offline
Need wiring harness
New to this purchased a used coolster 125 had it running great did not realize there was a hole in the fuel tank so caught fire and trying to find the correct wiring harness for it leaving some help on determining model and also which wiring harness should I use please help
This is the number off of the swing arm You cannot make out the plate
OZSCJLA2K1008311
NOV
Please Help Thanks
Old 06-13-2024, 10:25 PM   #2
shad88   shad88 is offline
Pull the cover off the left side of the engine and determine if you have a 2 pole or 6 pole stator. Search Amazon or eBay and find a complete wiring harness for a TaoTao or Coolster ATV with the correct stator. Shouldn't be more than $35.
Old 06-13-2024, 11:04 PM   #3
You can use an Ethernet cable for all data and signal wires outside of the starter, stator, and possibly headlight. It only handles about 1A per wire, too little for incandescent or halogen bulbs, and possibly led lights higher than 12W.
Old 06-15-2024, 11:42 PM   #4
Wire harness for your Coolster ATV-3125R can be ordered from their website;
https://coolster.com/product/complet...-29-dql-ea012/
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 06-18-2024, 04:20 PM   #5
buzz   buzz is offline
Walmart
