Old 07-22-2024, 04:47 AM   #1
Trynarideforcheap   Trynarideforcheap is offline
Orion rxb150xl
I need help finding a manual or specs and parts for a Orion rxb150xl does anyone know of anything.
Old 07-22-2024, 08:26 AM   #2
dirtbkr188   dirtbkr188 is offline
dirtbkr188's Avatar
Parts can be found HERE
Old 07-22-2024, 01:43 PM   #3
So I ended up buying a 2022 Orion 150dl without doing much research and now I found out they make the 190l instead of the 150 I started having problem after my buddy stalled it a bunch I started hearing rattling and we found out that came from the skid plate and the starter was really loose and that’s how I found the cracks they are bad and it still runs fine just makes a weird vibrating or knocking sound of metal on metal it doesn’t sound like engine tik or anything I just can’t figure it out would it be smarter to just engine swap it to a 190l engine
Old 07-22-2024, 03:45 PM   #4
Thumper   Thumper is online now
Sounds like a plan.
-NOS 2020 KTM 250SX (2-stroke motocross)
Old 07-23-2024, 01:29 AM   #5
Sounds like a plan.
Thing is id like to have to put as little money in it as possible and keep the original engine and I talked to Orion power sports and they said the the 190xl has a frame that’s two inch’s longer so I wouldn’t be able to do swap unless I fabricated something up
Old 07-23-2024, 05:09 AM   #6
Oh. Not a plan. Or go for it.
Cracks? Starter? Got pics?
Old 08-30-2024, 11:46 AM   #7
So the starter ended up completely cracking off I dried to jb weld it back to gather and it cracked off again so now it’s quick start only but when I ride it there is raffling some of it comes from the kickstart just vibrating on swivel it’s connected too but there is more raffling sounds like it’s at the front of the bike or engine I think it’s my valves or rockers and lifters hitting and I think they need adjusted but can’t find the correct lashing gap for it would anyone know anything? Or have a manual
Old 09-01-2024, 09:31 PM   #8
Is the 2021 orion rxb 150xl a wet clutch or dry and what oil does it take
Old 09-02-2024, 12:53 PM   #9
zero_dgz   zero_dgz is offline
It is definitely a wet clutch, and it will take any JASO MA or MA2 rated oil, the weight of which will depend on your locations temperature/climate.
That said, my buddy who has one runs 15W40 (yes, Rotella of course) in his since the temperature range seems to encompass everything we experience and then some.
Old 09-09-2024, 05:47 AM   #10
Thank you I haven’t been able to find anything on this bike and I’m just tryna keep it in good shape by chance would you know anything about the carb tuning or the lashing/gap size and so even though the rotella 15w40 is for a diesel engines it still works? I thought you needed wet clutch rated oil
Old 09-09-2024, 07:44 AM   #11
Can't install a new starter?
If necessary, tap new thread, and use a size bigger bolts if necessary.
Old 09-09-2024, 11:56 AM   #12
The Rotella 15w40 specifically is JASO MA and MA2 rated for use with wet clutches. Check the list of certifications on the back. I use it in almost all of my motorcycles and have done for years.
In general the valve clearances on these small engines should be around 0.06mm on the intake and 0.08mm on the exhaust on a cold engine. Be careful of people blithely spouting numbers online without units -- do not mix up inches and millimeters.
Some people prefer to run tighter clearances. 0.05 or 0.04. I don't.
orion rxb150xl
