Old 09-14-2024, 04:20 PM   #1
drivesslow   drivesslow is offline
Need help 125cc Grom clone
I made a pretty stupid and big mistake over the week. Was going for a simple oil change on the grom clone, this is the second time since receiving the bike and I wasn’t careful. Instead of undoing the oil drain it appears I undid the timing chain tensioner plug thing. It popped out with the spring and the plunger.
The even dumber part was I put the spring in first and then the plunger on a very uneducated guess and was very clearly wrong. Started the bike up and it started to rattle. I stopped and pulled the plunger back out first but the spring did not follow. I’ve tried to fish out the spring but it is lost in the motor. I tried today after getting a set of motorcycle flywheel pullers to get into the motor but I could not get the flywheel off. Nothing in the set worked.
I really just need help on how to access that area. Im not really familiar with small engines but I have dropped the motor on this before to upgrade the motor mount bolts.
What do I need to do in terms of access and tools to get into the engine and get this spring out??
Old 09-14-2024, 09:30 PM   #2
Crossbar   Crossbar is offline
Not familiar with that motor but I would probably pull the head/cylinder and have a magnet fish around first. Cracking the crankcase is a lot of work. Might could even get lucky via the dipstick access depending on size of the spring. Feel your pain on that one..
Old 09-16-2024, 04:58 PM   #3
4T_Goblin   4T_Goblin is offline
4T_Goblin's Avatar
Look at the motion pro fly wheel puller tool. I used it with success. I tried other kinds of puller tool and only ended up with a mushroom end on the shaft. I had to file it down and die it.
2020 Vader X-Pro X-7
2019 Kawasaki Ninja ex400
2022 Lifan KPX 250
Old 09-16-2024, 09:00 PM   #4
danklyrides   danklyrides is offline
There is a chance that you may be able to remove the valve cover and locate the screw by looking down the side of the cam chain and rotating the engine? I would definitely try that first because it is so easy to get the valve cover off.
If you do need to pull the flywheel, this puller should work well for you.
Let us know how you do. Good luck!
Cheers!
Dankly
Name:	Flywheel puller.jpg
