07-23-2024, 06:20 PM | #1 |
Please help
Hey, I just started working on a china dirt bike for the first time. It's a 2022 templar X 250. I am doing maintenance and upgrades. I have run into a problem and hope that someone can help...I need the front hub assembly with bearings or the entire front rim. It is a J 21x1.60 6 hole. I found that x-pro has one in their catalog but it is listed as "currently unavailable"...
The right side bearing has spun in the housing causing nearly 3mm diameter of damage. I am in the process of looking for an oversized bearing but haven't had any luck yet and my bearing seal, or any other im afraid, will no longer fit once it is cleaned and prepped for the bigger bearing. Please help and thanks. |
07-23-2024, 06:33 PM | #2 |
The measurements and identity of the OEM bearings are described here.
https://www.chinariders.net/showpost...postcount=4008 AND post #4 in this thread https://www.chinariders.net/showthread.php?t=32177 The Axel, bearings, seals are identical to those Honda (and KTM) models. There are TONS of sources for ALL of these front axel parts. You can spend a lot, or find bargains. But easy to find Perfect for replacement hubs are available, and here is an example of assembled wheels available - KKE laced wheel for $200 It looks like the identical wheel that comes with the Templar. It comes with bearings/seals and spacers. KKE also makes the front forks and rear shock on the Templar.
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 07-24-2024 at 08:34 AM. |
07-23-2024, 08:14 PM | #3 |
Hi...
If you are unable to get a new hub... what is the bearing number.. or the sizes ID and OD.. the bearing is most lightly a deep groove ball race.. 62XX maybe a (6203)? 03 = 17mm bore... So the next size bigger in the outer race will be a 63XX Here is a list of possible bearings from the SKF catalogue.. 15mm bore.. 6002 = 32mm OD 6202 = 35mm OD 6302 = 42mm OD 17mm bore.. 6203 = 40mm OD 6303 = 47mm OD 6403 = 62mm OD 20mm bore.. 6204 = 47mm OD 6304 = 52mm OD 6404 = 72mm OD .
07-23-2024, 09:05 PM | #4 |
Used Honda wheel on ebay
