Thread Tools Display Modes
Old 10-21-2024, 10:04 AM   #1
beniciolopez   beniciolopez is offline
flywing mx100 runs than stalls
flywing mx100 runs than stalls then won't start any ideas?
Old 10-21-2024, 08:09 PM   #2
TominMO   TominMO is offline
Out of gas?
Valves need adjusting?
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired.
Old 10-22-2024, 08:48 AM   #3
what?
Old 10-22-2024, 09:37 AM   #4
Benicio,
Low fuel in the tank can actually cause this (maybe fuel line or filter issue).
BUT, it sounds like you may have a blocked fuel inlet in the carburetor (float bowl valve) or other fueling issue. Hey, it starts right?!
First step might be to see if you have free flow to the carb.
1- discomnect the fuel line right at the inlet to the carb. The fuel should freely flow out the tube from the tank.
2- remove the float bowl drain. Again, fuel should freely flow out continuously.
All else fails, pull the cab and check the float bowl valve. May not be opening. Bend the tab to allow fuel to flow in.
Messy business, but you do seem to have a fuel flow problem. It could also be a dirty pilot jet/blocked.
No matter where you go, there you are
Old 10-23-2024, 09:04 AM   #5
thanks!
