35mm pod filter tube with fuel vacuum line?
Ever since I removed the stock airbox on my Vader, I have a fuel vapor line from the tank, I just plugged.
What I was wondering, is if there is an easy way to mount the fuel vapor line from the tank, to the pod air filter, maybe a small tube between the filter and the carburetor? I could drill a hole in the rubber mount, and insert the hose in that, but I was hoping for a more elegant or lasting way to do this. |
