Old 11-05-2024, 04:23 PM   #1
PhantomRider86   PhantomRider86 is offline
PhantomRider86's Avatar
Exclamation Spring rate for XPro X28, 110cc
Hello everyone,
I had recently bought the XPro X28, 110cc engine for my son.
Does anyone who is familiar with this bike know what the OEM spring rate is? I'd like to have a reference as to what the OEM spring rate is for the shock for when/if I buy an aftermarket replacement.
I am currently looking at a DNM MK-AR, 250LBS, 265mm, Rear Shock Spring (on Amazon) as a replacement. It has the lowest spring rate that I have seen available. Most others are in the 800-1000lbs ratings.
Any assistance/information on the stock shock would help. Thank you.
Old 11-17-2024, 04:51 PM   #2
Jtphotography0302   Jtphotography0302 is offline
I don't know but i am curious as well. Just bought one for my son as well. Good little bike so far. Very impressed with the quality. He struggles kick starting it.
Has a few bolts back out, and his chain has to be tightened often. I assume these cheap chains stretch a good bit.
He did lay it down in the woods. Bike seems tough.
110cc, spring rate, xpro 28
