06-09-2018, 09:31 PM | #1 |
Heated Grips
Can my new Hawk 250 handle the electrical load of heated grips? and what is the max wattage the Hawk 250 stater can reliably handle?
06-09-2018, 10:17 PM | #2 |
good question
like you i would like to know that too, the fuse link is like old shcool ,?what is the fuse in there being replaced with a 20 amp fuse an an upgraded stator should be good for that,i think i hear its not bad ,i also wonder if guys are upgradeing the battery as well i would like to power some things up too combo battery stater an new style fuse link ??? has anyone done this to there hawk yet thank you
06-09-2018, 11:01 PM | #3 |
The typical 8 pole stator as found in the Hawk is rate to around 100W. http://www.chinariders.net/showpost....52&postcount=3
06-10-2018, 01:10 PM | #4 |
Thank you for the info. fyi i found out that the heated grips pull around 20w so i should be ok.
