07-04-2020, 10:33 AM | #1 |
Orion RXB-250L, opinions?
Anyone have any experience with the Orion RXB-250L? I have seen a few reviews on the RXB-250 on youtube but can't really find anything on the "L". I would like to get a decent commute bike and want something that will run comfortably at 63-65 mph to work. It'll be mostly county roads and state highways (with some dirt roads and light trails) so I won't need 70-75 mph interstate speeds.
I posted yesterday about some higher priced bikes (GPX and SSR) but I think I am going to stick to the $2,500 and below range. Thanks for any help or direction................ |
07-04-2020, 11:39 AM | #2 | |
"L"
Not sure about top speed for this bike, but most 250's top out at the 63-65 that you mention with the right rear sprocket. I have a CSC TT250 (CG engine) with a 47 rear sprocket (50 is stock for more off-road applications), aftermarket exhaust and a larger carb with street tires that tops out right in that range. FYI...the TT250 is $2600 delivered, assembled. It is also fully backed by CSC in terms of virtually all parts, phone and e-mail technical assistance, and detailed technical service manuals. The seat will also be better for commuting (especially if you get the upgraded Seat Concepts seat...it is $250 though). There is also a 12-month unlimited mileage parts warranty. I have had a good experience with Orion, but they are no where near the level of assistance (technical and parts) as CSC. https://www.cscmotorcycles.com/defau...=xAllInventory The RXB250 would be better if you plan on more off-roading, as it has a better suspension for this. So, if you are 70/30 I would do the TT250. If 30/70 the RXB250. I have attached a photo of my commuter and also a detail shot of the pannier rack I built for it. Also, make sure you can license the RXB250 in Texas. In California it is not possible because it is not EPA certified and now in Colorado (where I am) they need to have some sort of certification for safety from what I hear. I'll find out soon when I try to plate my RXB150XL. The TT250 is not an issue. It is 50-state certified.
CSC TT250 Orion RXB 150XL |
07-04-2020, 03:16 PM | #3 |
Good job on the stand offs Goob !!! the panniers are the perfect size, where did you buy them? or brand.
07-05-2020, 11:06 AM | #4 | |
Nelson-Rigg
I have attached a couple of photos with the grocery load I carried. One shot un-loaded and one loaded. About 50 pounds. Prior to these, I tried using a large folding crate on the back rack, but the load was too high and yanked me around on turns. The panniers carry more and the load is low..no effect on handling. The rack mainly supports the panniers laterally, as most of the weight is put on the two straps that go under the seat between the two. This keeps the panniers square, and not sagging, and out of the wheel. FYI, I used Makerpipe.com 3/4" EMT connectors and EMT for the rack. Check out their site. https://www.amazon.com/SE-3050-Saddl...s%2C179&sr=8-3
