Old 12-15-2015, 07:50 PM   #1
RX3James   RX3James is offline
RX3James's Avatar
RX3 Shut off while riding
OK OK OK....
So today for about the 6th time my RX3 just completely shut itself off electrically while riding. I'm just riding along, the tach goes to zero, the engine shuts off and the red engine light starts flashing.
Every time this has happened the circumstances have been similar. Just leaving the house or work, get about 2 blocks away and then it dies. Roll to a stop, pull in the clutch and try to restart it. ( I've noticed the RX3 doesn't really like to start while in gear and the clutch pulled in ) Shift it into neutral and after a few cranks she generally fires right up and I ride on. The first time it happened I didn't really think about it too much but now that its happened so many times it's starting to concern me more. Thank god this hasn't happened while riding on the highway or through town in busy traffic.
I have been racking my brain trying to think of any thing that I may have done to cause this issue. The only thing that I can think of is when I was checking my air filter a few weeks back I found a section of the wiring harness was in the way of the filter cover making it really painful to get to. I noticed a small hook or slot on the frame where it looked like the wiring harness belonged so I relocated the harness to that position and re zip tied it. I looked over all the connections and I didn't notice any thing loose or unplugged. Other than that I haven't messed with anything electrical at all on the bike.
So has anyone else had this issue or anything similar?
Old 12-15-2015, 07:59 PM   #2
jbfla   jbfla is offline
Sorry to hear about the shut off problem...can't help you there.
I did the same thing with the wiring harness blocking the air filter.
Now I'm thinking I should remove the harness from the hook in fear of it rubbing against the edges of the hook and causing an electrical problem.
jb
2014 XT 250........
Old 12-15-2015, 09:08 PM   #3
Is the engine warning light flashing a DTC (diagnostic trouble code)? Have you checked the battery for low voltage, or a dead cell? Have you checked the valve clearances?
Old 12-15-2015, 11:53 PM   #4
RX3James's Avatar
The battery is only a few weeks old and it came from batteries plus with a two year warranty. I haven't checked the voltage yet. I'll have to check that tomorrow. I did the valve adjustment about 500 miles ago. But that's interesting.... Because honestly I do not remember this problem before I adjusted the valves. So perhaps you're on to something? Maybe I should take another look at my clearances this upcoming weekend!
Old 12-15-2015, 11:57 PM   #5
RX3James's Avatar
Also... I've done the diagnostic check and it didn't give me any blinking lights or do anything other than the normal display and start up procedure.
Old 12-16-2015, 01:13 AM   #6
Good for you. I do recommend you check the battery first. If battery voltage is low, you will experience the problems you reported. If all cells of the battery are good, then you certainly should check the valve lash. Also, make sure the spark plug cap is securely attached to the spark plug. Please do keep us updated.
Old 12-16-2015, 05:55 AM   #7
Tiger12XC   Tiger12XC is offline
Tiger12XC's Avatar
Originally Posted by RX3James View Post
OK OK OK....
Here is a problem Andy had with his bike over on the RX3 forums. Dirty ignition switch, he also said check the valve adjustment I hope this helps. Though I am having trouble finding the post someone had problems with an oily Mass Airflow Sensor causing stalling.
http://www.rx3forums.com/forums/show...gnition+switch
Old 12-16-2015, 08:25 AM   #8
Jay In Milpitas's Avatar
Stalling and Air Flow Sensor
Here's the post Tiger mentioned: http://www.rx3forums.com/forums/show...-loosing-power
Old 12-16-2015, 08:28 AM   #9
Tiger12XC's Avatar
Originally Posted by Jay In Milpitas View Post
Thanks Jay I remembered reading it but couldn't locate it.
Old 12-16-2015, 11:03 AM   #10
...someone had problems with an oily Mass Airflow Sensor causing stalling.
For the unfamiliar, you can buy mass airflow sensor spray cleaner at most auto parts stores. CRC makes such a product.
Old 12-16-2015, 11:08 AM   #11
katflap   katflap is offline
katflap's Avatar
I had mine cut out once a while back but only for a few seconds. My post on it is buried deep some where in the mega thread.
Turned out to be a bit of corrosion on the ignition switch contacts.
Cleaned them up and smeared them in silicone grease, never had a problem since.
The ignition switch comes apart pretty easily, without to much risk of springs, balls and contacts flying every where.
I hope your problem is sorted as easily as mine was
Old 12-16-2015, 12:54 PM   #12
Actually, the device Andy mentioned is not an mass airflow sensor, it is a manifold air pressure (MAP)/ manifold air temperature (MAT) sensor. Here is a photograph of both sides of the MAP/MAT sensor.
This sensor is located in the intake manifold, downstream from the throttle tube, but upstream from the fuel injector. The MAP/MAT sensor is shown inside the orange oval in the photograph below.
Because of its location, orientation and construction, I don't think the MAP/MAT sensor needs to be cleaned periodically like a mass airflow sensor. For some reason, Andy's sensor was oily. It's good to check this sensor, but I don't think it's a common problem for this sensor to get dirty.
Old 12-16-2015, 12:57 PM   #13
Here is a problem Andy had with his bike over on the RX3 forums. Dirty ignition switch, he also said check the valve adjustment I hope this helps...
Thanks for posting the good information on the ignition switch, gentlemen. Indeed, this is a good item to check. Next riding season I am going to clean my ignition switch, and slather the contacts with dielectric grease.
Old 12-16-2015, 08:20 PM   #14
RX3James's Avatar
Today I checked battery voltage. It's good to go. I think the valves are probably good as well. they're not making any strange noises or tapping too loud. I am going to explore the ignition switch this weekend and see if that yields any results. I'm going to take a close look at the MAP/MAT sensor as well.
I rode the bike to work today and had no issues other than the extreme cold we're dealing with down here in SoCal LOL.... No but seriously my face is getting a little cold in the mornings... 46 is cold!
Old 12-16-2015, 09:48 PM   #15
Today I checked battery voltage. It's good to go. I think the valves are probably good as well. they're not making any strange noises or tapping too loud. I am going to explore the ignition switch this weekend and see if that yields any results. I'm going to take a close look at the MAP/MAT sensor as well...
Tight valves will cause the problems you are experiencing, and they don't make any noise. Only loose valves make noise. If you want to check the MAP/MAT sensor, you will need to remove the fuel tank, so you really should check the valve lash while you are in there.
