Old 09-28-2024, 06:29 PM   #1
woodywood57   woodywood57 is offline
Tao tao 110 quad
I have a 110 quad I am bringing back to life. While checking the timing spining the engine over by hand, spark plug out, there is a tight spot in the engine. To me that means a crank/main bearing problem. Anyone else ever had that issue? It should spin freely with the plug out?
Old 10-21-2024, 08:51 PM   #2
darren   darren is offline
if timing is good ,stator is not broken or piston not scored what's compression like ?
Old 10-22-2024, 01:55 AM   #3
Thumper   Thumper is online now
The valve springs still can cause resistance to rotation. If it is smooth resistance, could just be that. Should be zero resistance approaching TDC on the firing stroke. Since valves should be fully closed. Grinding or grating, or chunky...bad.
No matter where you go, there you are
