Thread Tools Display Modes
Old 11-15-2024, 06:36 PM   #1
Hawk 250 pnw   Hawk 250 pnw is offline
Kayo k6 / nc250s/ zs177mn service manual & engine parts manual
KAYO K6 ENGINE MANUAL, NC250S ENGINE MANUAL, NC250S PARTS MANUAL, NC250 DOHC MANUAL
After going down a deep rabbit hole after my kayo k6 decided to bend its exhaust valves and throw off its timing, I've discovered lots of information that is very hard to find on the internet as we all know most Chinese bikes are similar well I found out that the nc250s/ ZS177MN is the same as the NC300 / ZS177MN. Except for the 82mm piston /cyl.
So all the ENGINE parts for a GPX FSE300 4-STROKE & SSR 300S WILL WORK
In fact I've ordered a NC300S/ ZS182MN cyl / piston kit & plan on installing that on my KAYO K6 to essentially make it the NC300S/ZS182MN. I went and measured everything and it will bolt right up and fit no problem. Upgrading it from a 250 to a 283.
https://www.dropbox.com/scl/fi/zr9az...5ei1v6uhp&dl=0
https://www.dropbox.com/scl/fi/tyb7d...gcwi6nbtb&dl=0
