Q1. WHERE CAN I BUY A REPLACEMENT BATTERY FOR MY SSR XF250 DUAL SPORT? WILL THE Fire Power HJTZ5S-FP Featherweight Lithium Battery WORK? HOW MANY AMP HRS IS THIS BATTERY? IS THERE ANYTHING CHEAPER? I CAN'T FIND ANY BATTERIES TO FIT 12V 9AH CAN I BUY ONE ON AMAZON? I PURCHASED THIS BIKE FROM MY NEPHEW AND HE HAD A MIGHTY MAX MODEL YTX 4L-BS 12V 3AH APPROX DIM 3.5 H X 4.5 L X 2.75 D. IS THAT THE CORRECT SIZE FOR THE STOCK BATTERY 12V 9AH? I CAN FIND ONE THAT MEET THIS CRTERIA. WHAT SIZE IS THE ORIG BATTERY THAT FITS IN THE SSR XF250 BATTERY COMPARTMENT? Q2. I CAN'T FIND PARTS FOR THIS BIKE. I LIVE IN QUEEN CREEK ARIZONA. Q3. HOW MUCH 4 STROKE MOTOR OIL DOES THIS BIKE HOLD? IT DOES NOT SPECIFY IN THE OWNERS MANUAL.: thanks: KINGKEYS
Amazon or Walmart.com. Another Mighty Max like you have in there would be an decent replacement. 3AH is fine but 4AH would be better. You can get an expensive lithium battery but it won't last any longer in my experience.
Oil capacity is 1400ml according to the side case. With an oil and filter change make it 1500ml. I use Shell Rotella or occassionally Mobil Delvac 15-40. Tractor Supply had 2.5 gallon jugs of Mobil for $20 ish a while back. For oil filters or any other engine parts, parts are interchangeable with the Suzuki TU250x. Good luck!
2013 SSR XF-250 |
