Old 02-01-2019, 11:49 AM   #1
Maplicito   Maplicito is offline
Spark plug for GIO 250's?
Does anyone have a recommendation for spark plugs for the GIO 250's? I believe it's a Zongshen CB250 motor in all of them - I'm hoping for a recommendation from one of the major spark plug lines like NKG. Thanks!
Old 02-01-2019, 11:54 AM   #2
NGK DPR8EIX-9 Iridium IX Spark Plug (2202). Same plug that most of the CG250 people use.
2004 Honda ST 1300
Old 02-01-2019, 04:52 PM   #3
humanbeing's Avatar
NGK DPR8EIX-9 Iridium IX Spark Plug (2202)...
Q's about that end cap http://chinariders.net/showthread.php?t=19826 http://chinariders.net/showthread.php?t=18413
Old 02-01-2019, 06:15 PM   #4
Originally Posted by humanbeing View Post
End cap is removable.
2004 Honda ST 1300
Old 02-02-2019, 09:10 AM   #5
I did some deeper digging, and saw DR8EA or D8EA by NGK suggested as well - taking a look at NGK's codes, all these plugs have the same heat range, it's just a question of resistor vs non resistor, iridium vs non-iridium, and whether or not it's the projected insulator? In other words all those plugs SHOULD work okay? Asking, not stating - I'm definitely not a spark plug expert.
Old 02-02-2019, 11:03 AM   #6
Azhule   Azhule is offline
https://www.sparkplug-crossreference...rt/NGK_PN/D8EA
https://www.sparkplug-crossreference.../NGK_PN/DR8EA/
For your "spark plug cross reference needs"
Don't forget that Denso also makes really good spark plugs... and they can be found for a little less coin compared to NGK's
Old 02-02-2019, 11:06 AM   #7
Awesome - thanks for the help! I'm not familiar with Denso... I know NGK, Bosch, Champion... but I'm definitely not opposed to going with a different company and saving money if the plug is still good. Thanks again!
