04-28-2021, 12:40 PM | #1 |
glass lens for headlight
Do they make a glass lens that will fit retro style scooters? or should i just replace it with a motorcycle one?
04-28-2021, 07:25 PM | #2 |
glass headlights are basically a thing of the past. They might be available but not nearly in production as mass market plastics.
If you want to find a legit glass lamp then i'd say best bet would be scrounging a motorcycle scrap yard. Do aftermarket glass headlamps exist? sure but they are expensive. Not sure what look you are going for, but just do a basic search in the online product site you prefer and something will come up. benefits of modern aftermarket plastics will likely be less weight, LED, more functionality, plug n go and cheap. |
04-29-2021, 01:03 AM | #3 |
what i'm looking to do is upgrade the lamp bulb to a krypton one. but they burn hotter and have a tenancy to melt the plastic lens. that's why i was wondering if they made glass ones still.
04-29-2021, 03:56 PM | #4 |
LED is now comparable or brighter than certain KW HIDs. Also cheaper, and longer lasting with less ancillaries. I'd look into the bulbs first, before going to HIDs.
