Old 11-11-2024, 03:39 PM   #1
stoppre12211   stoppre12211 is offline
big bore kit wrist pin sleeve/bushing for 223cc/zs165mm engine
hey guys.
Not sure if this is a bad solution, but I was really hoping to bore out my 223cc/zs165mm on my Vitacci Titan EFI. The only bore kit that fits the 15mm wrist pin available will go from a 65mm piston to a 67mm piston. I dont find that gain worth the effort. But I was wondering, could I use 15mmIDx16mm or 17mm to fit the larger wrist pin requirements of other cg250 big bore kit. Just raise the wrist pin OD to fit the 17mm 72mm-75mm bore kits. Let me know what you think.
I know its going to have ramifications to compression ratio and EFI flash but would this wrist pin sleeve solution even be viable. thanks.
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
Old 11-11-2024, 08:35 PM   #2
slithica   slithica is offline
Do not do what you are thinking, it's stupid.
There are also multiple ones listed on ebay. Don't buy one larger than 70mm. You'll regret it.
Did a quick google, your engine should be a cb250d-g. ignore the above link(removed)
Basically no, there are no big bore kits for your engine. Get a bigger engine.
Maybe an XR250R engine swap?
https://www.alibaba.com/product-deta...174950828.html
possibly something like that?
One guy bought an actual honda engine though.
https://www.chinariders.net/showthre...t=21224&page=2
