Old 03-20-2020, 07:13 PM   #1
maupin81   maupin81 is offline
Tbr7 chain
Yes I Recently noticed the chain on my bike has some loose spots on it Half of the chain is in spec right where I want it but the other half is pretty loose should I tighten it because I don't want the other part to get to Tight
Old 03-20-2020, 10:11 PM   #2
It's normal for a chain to have sections be tighter or looser than others. In fact, you should always set chain tension based on the tightest spot on the chain.
Old 03-21-2020, 03:56 PM   #3
OneLeggedRider's Avatar
What the??? If your chain tension changes as you roll it around the sprockets you've got a cheap/junk chain, or one of your sprockets is off center or worn. A quality O-ring chain will maintain constant tension.
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
