12-20-2018, 12:36 PM | #1 |
200cc ohc lifan motor
I was given a 200cc ohc 5 speed lifan motor that has never been started my son and i are going to install it on his mini bike through the winter can somebody please tell me if i need a ac or dc cdi box how can i find out i have motor only need to purchase wire harness and all the electronics thanks for your help
12-21-2018, 07:57 AM | #2 |
Most likely an AC but could be DC, actually if you get it wrong or have a loom that is say AC but you need DC then I can special order a CDI to suit the motor.
AC and DC plugs differ but there is a work around. Wait if you put power to the starter and crank do you get about 50 volts AC voltage from the Blue white wire? Something like that is how you could test it with a volt meter. |
12-21-2018, 11:18 AM | #3 |
For all it is worth, see if American Lifan can help you.
12-21-2018, 02:56 PM | #4 |
Most ac-in = red/black. blue/white is trigger line. Test w/ meter is the ONLY way to knew what's inside.
12-27-2018, 10:02 AM | #5 |
Thanks for the feed back just got back in town from the holidays I will try the voltmeter see what reading I get
12-27-2018, 10:05 AM | #6 |
Can you please tell me what size sprocket that I need to purchase is it 16 mm 17 mm 18 mm I'm not sure which one to buy the sprocket for the motor thanks for all your help 200cc lifan ohc
12-27-2018, 03:44 PM | #7 |
http://chinariders.net/showthread.ph...559#post184559
From memory Lifan is the 5mm variety that uses JTF1264 that unlike mainstream 4mm
12-27-2018, 04:25 PM | #8 |
My Lifan CG 200 engines use the JTF 1264.
01-04-2019, 03:20 AM | #9 | |
This must be the AC ignition yes? 4 stator wires red being the input volts for CDI Blue white trigger and green white eart of trigger. Other 3 are the charging wires. Found this while I am trying to work out what I have on my CQR I know it is DC CDI but wondering why my Tacho is slow - yet plugs are square which I thought meant AC? |
