Old 01-26-2007, 08:19 AM   #1
Trubattleax   Trubattleax is offline
differences in the two types of zonsheng motors.
how do u tell the difference in the two types of motors theres a over head cam and a push rod motor. how do u tell the two apart?
Old 01-26-2007, 03:23 PM   #2
czowner   czowner is offline
The difference is.....
An OHC motor has a round casing about 3 inches across on the LH of the cylinder head.
Jonathan.
Old 01-26-2007, 03:39 PM   #3
RPM   RPM is offline
Send a message via Yahoo to RPM
That's correct. If you remove this cover, you will see the cam chain and sprocket inside. You will also have two identical round covers located above the exhaust and the intake valves on top. This, of course, signifies an overhead cam (OHC). http://chinariders.net/gallery2/main.php?g2_itemId=126
The overhead valve (OHV) engine will have a single, one piece cover that you have to take off to access the valves and it covers the top of the head. Pics of this type are in Frostbit'e gallery pics. http://chinariders.net/gallery2/main.php?g2_itemId=329
RPM - REV IT UP! (REDLINE is OPTIONAL)
Feel the RUSH ... it gets better all the time!
Old 02-04-2007, 08:42 PM   #4
thanks for info helped alot.
