Old 03-24-2008, 09:53 AM   #1
smokeeater   smokeeater is offline
carb adjustment
its been awhile since I messed around with carb adjustments and can't quite remember how to start. After fixing the electrical problem with my son's atv (70cc hensim tierra), Its tough to start and doesn't want to stay running. Can anyone give any good guesses as to how many turns out from closed to open the air mixture screw?
The problem is, I have to hold the throttle wide open for appx 15 sec, several times for it to start. choking it doesn't help
<div align="left">hensim 70cc atv, son's<br />'92&nbsp; 250x, mine<br />'01 recon, hers<br />'95 xcr 600<br />'89 four winns <br /></div>
Old 03-24-2008, 10:27 AM   #2
ejcycles's Avatar
Hi smokeeater
It sounds like you have an internal carburetor problem.
If you need to hold the throttle at W.O.T. to get it to start, it's flooding. Holding the throttle at W.O.T. lets more air in so it gets rid of the excess fuel and the engine will start a little easier after it gets rid of the fuel it doesn't need. The first thing you should do is get rid of the stock factory spark plug and install a NGK C6HSA and gap it at .026 thousandths. The second thing is to make sure that the float inside of the carburetor isn't sticking or dirt caught in it's needle. This is the biggest problem when a vehicle floods itself.
Old 03-24-2008, 12:05 PM   #3
I have a new c7hsa and the gap was right on. the tip is white, correct me if i am wrong, does this mean it has a lean mixture?
Old 03-24-2008, 03:44 PM   #4
nick780   nick780 is offline
smokeeater, yes i think i white tip means your running lean. and as for your fuel mixture screw, turn it clockwise untill you have it closed, then back it out 2 full turns, that should get you close to the right mixture,( clockwise=lean,,counterclockwise=rich),
2007 Roketa atv-61 300cc , 2003 suzuki LT-Z400,,jet kit,,white brothers exhaust
