axle nut
i need a new nut for my front axle on my shineray xy125gy would it be imperial sixe nut it seems around either an m12 or m14 but one is too big and the oyher is too small what size possibly would it be but i do not have the original as a sample can anyone help me many thanks
It's metric, trust me.
Not only is the axle metric, 12mm, there are 4 different thread pitches it could be, 1, 1.25, 1.5, 1.75. I'm in the middle of a storm right at the moment, if no one steps up, I'll measure the nut tomorrow afternoon. |
#3 | |
Re: axle nut
I believe my Gio quads are 12mm 1.5 thread pitch. You can buy a thread pitch gauge to check if nobody here knows. |
M12 X 1.25 (which is kind of an odd-ball thread)
Actually, a Dodge Mini-van uses this thread pitch on their wheel nuts, if "stuck" you could reverse, and use one (it would look goofy as all get out, but it should work). |
I think a 1.5 would be worse, but still an odd one to find.
Is it a castle nut too? I'd have no idea where to find something like that. |
Locally, I would check a nut and bolt supply, maybe a garage that specializes in front end work, and if a locking type nut was not available, i would drill the end of the axle for a cotter pin.
For your reading pleasure: http://en.wikipedia.org/wiki/ISO_metric_screw_thread Actually, in North America, the "usual" fine pitch for a 12mm bolt is 1.5, though most 12mm fasteners use the coarse pitch of 1.75 (meaning: you would be hard pressed to buy a tap, and die, set with this size in it). Changing the axle bolt with a "regular" 12mm bolt is a no-go because the shoulder on the bolt is sized to fit the front wheel bearings, though another axle bolt would do. |
#7 | |
Re: axle nut
