03-03-2017, 11:47 AM | #1 |
Apollo 350cc dirt bike
hi guys brand new to the form hereI have an 08 Apollo 250cc dirt bikegot the bike from a friend of mine gasoline was coming from the Overflow tube on the bottom of the bowl ordered a new card for good for about 20 minutes then started doing the same things I was wanting to see if anyone can give me the valve clearance on it and what the compression on it should be other than that it's a great riding bikeany input would be very much appreciated thank you I got the bike for nothing not wanting to put a lot of money in it would like to get it running good
03-03-2017, 12:02 PM | #3 |
yes it was sitting for 2 years I clean the tank out as best as I couldand it's a brand new Keenan 30 millimeter carburetorlike I said the bike runs great other than it coming out of the bottom of the bowl for the Overflowit can't find too much information around where I live on these types of bikes I was told it could be a tight valve or it could be a compression issue
03-03-2017, 12:03 PM | #4 |
was wanting to reset the valves today and try that and do a compression check on it
03-03-2017, 12:05 PM | #5 |
sounds more like it might be float adjustment.
I don't know the valves off hand, but I'd guess they might be close to what the hawk's motor is set at. if nothing else, you can do a search and find that info here. it's easy to pop the valve cover off. have you checked to see what the current settings are? |
03-03-2017, 01:13 PM | #6 |
no not yet any info I got from the bike shops around here they're saying it could be a tight valve exhaust got a little red at first when it was running good i didnt get red at all so that's what may be leading me to the valves
03-03-2017, 01:13 PM | #7 |
when the carburetor wasn't leaking from the Overflow it did not get red at all I should have said
