04-25-2016, 11:20 PM | #1 |
Storm 250 sprocket question
Well, I've put almost 100 miles on the Storm and love it!! It didn't take long though to notice the gearing (especially 1st gear) is too high of a ratio for comfortable street riding. I checked my bike tonight and the factory gearing is 17 tooth countersprocket combined with a 46 tooth rear sprocket.
Others on this forum have stated this sprocket is a direct bolt-on but I wanted to check as my current sprocket has only 4 holes while the suggested sprocket has six holes. Here's a pic of my current sprocket: As you can see there are 4 holes 90 degrees apart. I suspect two of the holes just wouldn't be used and just the 4 holes 90 degrees apart would line up with the factory hole locations. If anyone can weigh in on this I would appreciate your time. I know there's a fine line between having enough of a gear ratio for comfortable off-road riding to maintain while being able to maintain speeds on the street without excessive engine rpms. I was thinking a reduction in teeth from 46 to 42 that would give 9.5% increase in speed is a reasonable compromise as I'll be street riding at least 60-70% of the time, thoughts? |
04-26-2016, 07:06 AM | #2 |
If you have a digital caliper check the distance on those bolts, should be 90mm apart (to the center of each bolt) for the JT269 sprocket. I just put a JT269 sprocket on my 'Bashan WILL' and all I did was measure with a $12 digital caliper
I personally went with a 39t sprocket, for a few reasons, main one being... I got it from Amazon Prime shipped it for under $16 and I was on a 'budget' for 'upgrade parts' at the time Top speed should now be over 80mph... if the little 197cc engine has enough torque to pull that gearing I don't know just yet... still waiting on carburetor jets and finish my exhaust install.
04-26-2016, 07:53 AM | #3 | |
I'll check the hole distances with my calipers. Thanks for the info. |
04-26-2016, 08:45 AM | #4 |
Factory sprocket had 4 bolt holes and was a 56t for some reason...
4 bolts/holes 90mm apart, here is a pic of the JT269.39 (this sprocket has 8 holes) installed on the Mrs. Bashan WILL. Check the distance, if it's 90mm decide from there how much extra 'HP/Torque/MPH' you think the Storm 250 has to offer. Rider weight, motorcycle performance/weight, altitude, and several other factors come into play when choosing sprockets/gearing... again, I picked the 39t because it was in my budget and after I'm done with this Bashan build, I figured it would have plenty of extra 'oomph' for the 17t front 39t rear 'highway gearing'
04-26-2016, 09:54 AM | #5 | |
Unfortunately I want the best of both worlds but can't have it. I like the current gearing for off-road use but the current setup sucks for street use. |
04-26-2016, 11:15 AM | #6 | |
As you already know, round figures, one tooth more on the front is worth about 4 teeth less on the rear. Four teeth less on the rear would be a nice compromise and I think you'll be surprised at how much nicer it will feel on the road without giving up too much on the trail.
04-26-2016, 11:32 AM | #7 | |
06-19-2016, 07:39 PM | #8 |
great info for bashan storm/blaze bikes
azhule helped me with my chain/sprocket id .
i was directed to this thread so i thought i would bump it back out to let others know if they need info on their Bashans. Thanks again Azhule http://www.jtsprockets.com/catalogue/sprocket/JTR269-43
06-19-2016, 09:32 PM | #9 |
Glad I was able to point you into the right direction on your sprocket size, 90mm 4 bolt pattern seems to show up a lot on our favorite brand of motorcycles
Hope the 43t works for you, I know when the 39t starts to fail I will slap on the 43t and be 'done'. The 39t is extreme, our 197cc barely has enough oomph* to run that gearing (17t front), and I only weigh 120lbs *Bike runs ok but needed to be modded to run the 17t/39t sprockets (intake, exhaust, carb tuning out the yin yang...), with the 39t, 5th gear is now like having a 6th or maybe I jumped up to having a 7th gear in it's place , anyone else able to go just shy of 50 fully wrung out in 3rd... no?.. it's only me?
06-19-2016, 09:50 PM | #10 | |
this ought to be good
06-19-2016, 11:49 PM | #11 |
On most rides so far I can get it up to 60 sometimes 65 easily, top speed is 'unobtainable' in my tests thus far (damn you wind! can't you push me for once!) but I have nudged 70 once before and I still had plenty of RPMs left for more speed... just no extra oomph/power/torque to go faster or maintain that speed for that long... altitude, hills, wind, physics, still working on the tune, etc. is all holding me back a little bit ...
But I can cruise at 60 all day long with no problems
08-09-2022, 09:03 AM | #12 |
Original off center
How did you alighn the chain being that the original sproket is off center to the left, the new sproket would put the chain in the center and the slider would be off.
08-20-2022, 08:04 AM | #13 |
Sprocket change
The sprocket mod works good.
08-20-2022, 09:13 AM | #14 |
Bashan Storm is a great bike. Priced about the same as a TBR7, and way better build quality (we got a lemon TBR7-sold it).
JTR 279 and JTR 269 sprockets have the same measurements. http://www.jtsprockets.com/catalogue/part/JTR269/ http://www.jtsprockets.com/catalogue/part/JTR279/ I got a JTR 279-35 for my Storm, with a 520 chain upgrade: https://www.chinariders.net/showthread.php?t=30749 I modified washers to fit the sprocket, but it works fine. I actually dropped the gearing by about 7% for better offroad duty. My son has inherited the Storm, complete with Tusk DSport rear tire and Shinko 524 knobby on the front. He likes it geared down too. It is easier to ride slowly in technically challenging situations. Those tires help a lot!! I also changed the fork oil for Motul 15W. That really improved the front end. Stopped it from bottoming out all the time! |
