Old 04-01-2017, 06:10 PM   #1
Thegeekman   Thegeekman is offline
Gio 250 just died please help
I was out for a ride and my 2007 gio 250 just died lost all lights all electronics and won't turn over can't get it to do anything thought it was a fuse but i can't seem to find a fuse anywhere please help.
Old 04-01-2017, 06:32 PM   #2
MOTOXtreme   MOTOXtreme is offline
The very first thing you need to check is the battery voltage. Sounds like a charging system failure. Id start there anyway.
Brian
Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com
"Imagination is more important that knowledge" Albert Einstein
Old 04-01-2017, 06:52 PM   #3
Battery is good 12 volts even my charger said it had a full charge anything else you can think of
Old 04-01-2017, 06:57 PM   #4
pete   pete is offline
pete's Avatar
12 volts is low... should be 13 plus..
but it's enough...
there has to be a main fuse somewhere
look for a little white tube with a wire coming from each end
fuse is inside it... should be in the red "+" wire from the battrey...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
