Old 04-19-2021, 11:00 PM   #1
Slofun   Slofun is offline
Bottom oil drain plug torque setting.
The RPS Hawk 250 manual says to change the engine oil using the side drain plug and torque it to 18ft/lbs. To avoid the mess, I use the bottom plug for most oil changes. What’s the torque setting for the bottom plug? Is it 18 also?
Thanks a lot!!
Old 04-20-2021, 12:01 PM   #2
Tractor Tom   Tractor Tom is offline
I was also curious why they recommend using only using the side drain plug, must be because of the location of the filter screen. I just added an oil cooler that uses the side port so I'll be draining oil using the bottom plug. 18ft/lbs sounds about right, a general rule, plugs with a rubber o-rings don't need to be "reefed" on (as my old mechanic friends would say!).
Old 04-20-2021, 03:12 PM   #3
Wild Dog   Wild Dog is offline
Few blocks from my flat, i have a guy that has a workshop. You wouldn't belive all the CG he has to repair due damaged threads on the lower drain plug.
If you damage those threads, you have to split open the case to fix it.
ideally you should unplug both the side drain and the lower one. That way you can clean the filter and remove most if not all of the old oil.
Old 04-20-2021, 03:41 PM   #4
I now torque mine to 10 ft lbs with hylomar. Thread on issues.
http://www.chinariders.net/showthrea...ght=drain+plug
