04-03-2007, 01:04 AM | #1 |
adjusting Rear Shock
My wife told I should excersise more if I want to stiffen my rear end so I'd better rephrase this.
How about adjusting the mono shock on the bike? |
04-03-2007, 01:16 AM | #2 |
Depends on the shock that's installed. If it has a preload adjusting collar or a valving adjustment, then you're golden. The most I've seen on these bikes is a preload adjust. My rear shock has no adjustment whatsoever so the only option is to replace it with an adjustable model shock.
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
04-03-2007, 07:05 AM | #3 |
Molypod, read this entire thread. If you are experiencing a super stiff rear suspension that feels like you are riding on a brick, you'r gonna have to live with it unless you do something drastic like I have. Best of luck man, steer away from potholes!!!!!!
http://www.chinariders.net/modules.p...ewtopic&t=1315
04-03-2007, 12:09 PM | #4 | |
I've had the bike bottom out a couple times and was wondering if I could stiffen the rear up somehow. I primarily ride dirt and only ride the pavement short distances to get to the dirt and the shock has softened. Alot smoother ride now over washboard but on the bigger bumps even with standing up when I hit them the bike flexes quite a bit and bottoms out. The China bike has taken more and more abuse than I had intended but it takes it like it was meant to and I'm pushing it harder each ride. |
04-03-2007, 01:26 PM | #5 |
Got ya. It sounds like the shock is dead. I have my stocker with only 150 miles I'll sell you for cheap. Let me know.
04-03-2007, 01:49 PM | #6 |
Get down on the ground and look to see if has thread on the top or bottom. If it does just loosen the outer ring and the tighten up the inner one. You can use a spanner wrench or a big flat screwdriver and a hammer.
Stiffened mine up as well. I'm thinking about removing a top off a front shock to see if I can drill and tap in air valves so I can stiffen up the front as well... |
04-03-2007, 03:25 PM | #7 | |
04-03-2007, 04:52 PM | #8 | |
Thanks to everyone for your input and I am more than happy with my purchase and can't wait to get out a ride everyday when I'm home, Looking for every excuse to get on the bike " Really were out of milk again?? Hmm... I better get some for the kids cereal!" except I don't come home for two hours, usually forget the milk on the way home and I am so dirty my wife doesn't let me in the house without changing |
04-08-2007, 01:20 PM | #9 |
Here's what I got. from swing arm to mark on side panel weight off weight on ( full ride gear my full weight) I have 2" of sag.
here is a pic of the bottom of the Mono shock and what I think are the two collars for adjusting, I've never had to adjust a mono before. I assume I need to lossen the bottom collar, then tighen the top one to increase the sag? pic. http://www.chinariders.net/gallery2/...serialNumber=1 |
04-08-2007, 02:01 PM | #10 |
molypod
Correct, loosten bottom spanner nut, adjust the top one then lock them together. Bruce
04-08-2007, 02:04 PM | #11 |
Thanx bruce,
Best tools to use? Hammer and Large flat head screwdriver? looking at the notches that is what I would try. |
04-08-2007, 02:09 PM | #12 |
molypod
Yes that will work but be careful not to gouge the spanners, a long punch will work also. Bruce
04-08-2007, 05:22 PM | #13 |
Mine came with a spanner wrench but I didn't try it.
04-09-2007, 12:09 AM | #14 | |
Anyways.. I adjusted the spring to 2.5" of sag which is the most I could get.. ( maybe the scissor restricts the max amount) I took the bike for a great ride with some decent air time and there wasn't much change. the bike does compress well before the hit ( it does hit its stops on the front forks sometimes) but upon landing I still feel like there should be more travel then it has.. True its' not an XR or CR ( both of which I have owned) Nor is it a New CRF ( hmm maybe I shoud try one) but I feel there should be more I can get out of this bike with either adjustments or perhaps some new parts... Not complaining just trying to tweak this thing into the best off road bike I can get out of it. On the road it is just great and maybe because I have never owned a dualsport before I am expecting more than I should.. I think next, Some Kendal DOT Knobbies and maybe the Red2003 scissor mod. |
04-09-2007, 07:55 AM | #15 |
Molypod. What you are saying about the rear suspension I have addressed in my earlier posts. Trust me, it's not gonna get any better with adjustment. The rear suspension is only capable of about 3 inches of travel with the stock parts, and the last 1/2 in. of that is just the scissor parts being torn apart and flexing. Adjust all you want, it is what it is. The only fix is to eliminate the stock linkage. I wish I could have found a simpler fix (believe me, I tried) but it's not gonna happen, unfortunately :( . C'mon, take the plunge and rip that scissor linkage apart. I'll help any way I can .
