10-07-2020, 01:44 PM | #1 |
Instrument panel and engine start problem
Today i started my rx3 bike.
After some metres driving i realise that the instrument panel back light was "blinking" (on and off fast). I stopped and switch off the light and then.. my bike switched off! no panel display at all! I took off the ignition key, put it back again, switch it on and still nothing on the panel... I pressed the clutch an the panel indicators appear (while pressing the clutch) , but when i left the clutch nothing again! Also , only when the clutch remains pressing the rpm clock is working only. That way i managed to start the engine (after several times) but on the panel was only speedo, fuel and the gear number was flashing. I am really confused on what to do guys.. Is it a battery problem? Any advice would be appreciated! (My rx3 is 2015 model with 12000 km and i am sorry for my bad English!) |
10-07-2020, 02:27 PM | #2 |
Check that all of your grounds (earths) are tight, and make sure the battery terminals aren't loose.
10-07-2020, 03:42 PM | #3 |
second the grounds, the cluster is grounding thru whatever it can find to backfeed to ground.
10-08-2020, 01:59 PM | #4 |
problem solved!
@bogieboy
@franque Problem finally solved today! Spent 7 hours and the problem was at the key switch ignition lock. I had to take it off, open it , test it, repair it put it back and..worked like new! So thank you for your help! It is really nice knowing that someone will help you somehow! So, rx3-bikers see you again here! |
