Old 07-13-2010, 09:31 AM   #1
BigWill   BigWill is offline
Jmstar 150cc scooter shuting off
well the jmstar scooter i have was real nice. Until it started shutting off while rideing it. i would start it up then give it some throttle and it would just bog out and shut off any suggestion i would appriciate it. :(
Old 07-13-2010, 10:00 AM   #2
Cal25   Cal25 is offline
do you know if it is getting spark and fuel?
Old 07-13-2010, 12:18 PM   #3
Welcome!
That sounds like the stock spark plug. Have you tried a new NGK?
Old 07-22-2010, 09:37 AM   #4
Reveeen   Reveeen is offline
Sounds like a fuel "issue", but as was suggested, pull the plug (noting the colour) and replace it with an NGK.
Usually the plug colour will tell the tale and give you a direction to head in.
These scooters have some, well, kind of built-in problems:
The fuel/vacuum lines are made out of garbage. Try replacing all with quality stuff (being careful doing 1 at a time).
With the fuel tank under the floorboards in order to give you under seat storage, there is a vacuum operated fuel pump that can give trouble, so give it a look/test. These are non-rebuildable, replace only specimens, that will gum up (if fuel is allowed to dry in them), and stop working/working well.
The electric chokes affixed to the carburetors seem not to have a long life, and if stuck closed, can give you the trouble you describe (check plug colour). You can use an ohm meter, checking for 12V (with the key on running), and continuity (resistance) unplugged from the harness, they do sometimes "stick" internally, there is no test for this, only replacement.
If stored for a long time the carb will "gum up". carefully remove the float bowl and clean out everything with carb cleaner. There is a formed "O" ring on the bowl, that will immediately shrink, so running hot tap water over it (and GENTLY stretching it) will allow it's re-use.
General *thought* from around the different forums is that the carb can start giving trouble within 500 miles on these bikes, and they recommend replacement. Though none seem to advise replacement with what (all Chinese scooters seem to use the same carbs, so I have no idea what you would use to retain the existing features).
Old 07-22-2010, 10:42 AM   #5
Great information there. thanks!
