Old 12-18-2014, 08:48 PM   #1
neo0604   neo0604 is offline
please can anyone id this and wiring pin out
Hi guys im new here to this forum and really need to find what wires colour codes too go to this 6 pin cdi. its completely smooth with no names or part numbers. The prob i have is the wires were all taken out of cdi plug befor i got it.the colours are blue/white,green/white black/white, black/red not sure on the last wire. Id be so greatful if anyone can spare me this time this is regarding my wd250 baja atv
Old 12-18-2014, 11:52 PM   #2
Welcome!
Do you have a pic of the atv? I'm unfamiliar with that designation.
Old 12-19-2014, 04:36 AM   #3
humanbeing's Avatar
What's the bore & stroke & shape of the engine?
That 6 pin is found on some Yamaha.
http://www.jmtx168.cn/Knowledge/KnowCdiFaceF28_1.php
http://www.jmtx168.cn/Knowledge/KnowCdiFaceF28_2.php
http://www.jmtx168.cn/Knowledge/KnowCdiFaceF34.php
Old 12-19-2014, 07:42 AM   #4
thanks for replying guys i appreciate this very much.
These are thedetails of the stroke etc:,
Displacement 248ml
Bore×stroke 69×66.8
Compression ratio 9:1
This is my quad along with the front fairing thats off the vehicle its supposed to be a wd baja qj the engine num starts with a QJ 169MM*4000612* if this helps.
hope these help
Old 12-19-2014, 10:15 AM   #5
humanbeing's Avatar
Maybe similar to Majesty.
http://item.taobao.com/item.htm?id=19917785863
Old 12-19-2014, 10:47 AM   #6
The pics are a little tough to see on my monitor. Is that a liquid cooled GY6?
Old 12-19-2014, 11:16 AM   #7
really appreciate you all taking the time tohelp me i put some closer pics up as i wouldnt know what type of engine other than a 250cc but yes you are righ it is liquid cooled.
i know that it only had the five wires going to it which was blue/white, green/white, red/black, red/white, black/white, would the black/white(kill switch) be there instead of black(ground) are they not one and the same or are they entirely seperate or can i intergrate the b/w and b together
Old 12-20-2014, 11:27 AM   #8
That definitely looks like a liquid cooled GY6. If you look up the Honda Elite 250, you'll find a very similar motor.
Be careful; black is usually switched power on China bikes and atv's. Green is usually ground. What colours are connected to the kill switch?
Old 12-20-2014, 11:55 AM   #9
ive just managed to get the old pinout off another guy whos got identical set up the kill switch is black and white and black is the ground. im not sure what to look at replacing first as i did the stator tests and between the three white wires i get 7.2 volts each one is the same and ohms resistance is 1.6 to be honest i dont know what the actual tolerances are. but i still am not getting a spark
Old 12-20-2014, 07:35 PM   #10
humanbeing's Avatar
From the color code i'm 99.99% sure it's a Yammie clone.
Typical Yammie scooter
http://motosrv.ru/data/documents/Yam..._1995_1999.pdf
http://www.dansmc.com/electricaltesting.htm
