Old 06-03-2021, 11:17 AM   #1
BassmanBiker   BassmanBiker is offline
2020 SSR XF250 rim change
I am looking at going with a bigger front rim and tire on my xf250. I am new to the forum and have searched in previous threads for info on what fits the bike and have had no luck finding. Can someone lead me in the right direction on what will fit the bike, or direct me to a thread with this info.
Thanks n advance
Old 06-03-2021, 11:42 AM   #2
What size are you going to?
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 06-03-2021, 12:12 PM   #3
Stock it has 130/70-17 on rear and 110/70-17 on front. I am thinking a 19 on the front but i am new to dual sport bikes and am up for suggestions. I am planning on going to a little more aggressive tire like the Shinko 705 then the street tires it came with and thought i would go up on front rim while i am doing so.
Old 06-03-2021, 01:14 PM   #4
The 19" is ok compromise for road/trail. 21" is better for trails... but I like it on the street too.
Old 06-03-2021, 07:00 PM   #5
jcalis   jcalis is offline
17 rear will be fine for dualsport use, plenty of tires available.
I would gowith a 21" front if you can, that will give you the best selection of tires. Front end of your bike looks similar to an Orion RXB250L. If so Honda wheels may fit. I have an Orion and can compare front wheel measurements if you provide them.
2019 RPS Hawk, 2020 OrionRXB-250L
Old 06-03-2021, 11:21 PM   #6
The number on the front wheel is
J17 x MT 2.50 1218 DOT
Hoping this is what you are asking for I’m new to this.
Old 06-04-2021, 10:21 PM   #7
dh   dh is offline
If you would be happy with 19" then you are in luck. The bike comes withe either a 17" or 19" front wheel option. You can call SSR and order an OEM 19" wheel.
2013 SSR XF-250
Old 06-05-2021, 09:56 AM   #8
Those numbers describe the rim size. You need measurements of axle diameter and width to get an idea if a wheel will fit your bike. You would need a set of calipers to get decent measurements.
If you can easily get a19 from the dealer, that would be the way to go. It would fit without any modifications. Axle, hub, and brake rotor size would match.
Old 06-05-2021, 10:17 AM   #9
If it helps, I've got my 19" from my tbr7 that I can measure anything youd like me to. I know it's a 12mm axle, and will interchange with many of the conventional forked dual sports. Remember th dual sports have the tangs for the speedometer.
Old 06-05-2021, 10:48 AM   #10
dh   dh is offline
I was wrong. There is no 19" wheel standard. The dual sport comes with an 18" front wheel option with a fat front tire like mine. The supermoto comes with a 17 standard up front.
An 18" front wheel would give you more DS tire options but still limited. I have used both the Shinko 244 and 700 model tires. For an 18" wheel your front tire size will be 4.60-18.
2013 SSR XF-250
Old 06-05-2021, 10:54 AM   #11
dh   dh is offline
https://m.aliexpress.com/item/325985...bilesitedetail
21" front wheels used to be an option, and you can still get one apparently.
2013 SSR XF-250
Old 06-06-2021, 03:26 PM   #12
Thanks guys for all the responses and the link I think I may just order the 21” from the link.
Old 06-07-2021, 07:03 AM   #13
Be aware that your XF is Suzuki based so a DR200 (or other size) front tire might be a direct fit. Another option is to get a rim and have it laced to your hub. This might be the cheapest option based on the shipping charges from AliExpress.
Also, 2LZ's Qlink has a 21" front and may be a direct bolt on. You might still be able to order it.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 06-07-2021, 08:05 AM   #14
I've bought stuff from Roketa parts.com https://www.roketapartsdept.com/ as they carry parts for allot of Chinese bikes. If find your bike parts listed there or you find another that is similar, they probably have what you need. I got my front 21" rim from them, I just had to do some research for a similar model.
