Old 07-12-2024, 03:18 PM   #1
AcidicLactate   AcidicLactate is offline
Lifan Xpect Assembly Progress
Alright, I figured I'd do a bit of an update on my bike so far.
I've managed to regrease the swingarm and rear shock bearings, plus the rear wheel bearings and the steering stem bearings. Also I've managed to figure out through other posts where the diagnostic port probably is. I'll give an update on if it actually is it if I ever get the chance to use it. (Supposedly it's a euro5 port.) Beyond that, I need to replace the front sprocket and chain. Then reinstall the forks and the front wheel.
Side note, while checking it over I noticed a tiny bearing had fallen out from somewhere in the bike. Almost looks like one of the metal cylinders from the steering stem bearings, yet those don't fall out. Any clues as to where this bearing goes?
I don't think it goes to the rear shock or swing arm given that they're held on simply with a singular bolt...maybe the rear wheel? (Also sorry for never responding to comments,I can't quite figure out the controls in this forum ;-
