12-03-2018, 07:47 PM | #1 |
Oil/Winter
Dumb question but ummm what oil are we supposed to run? Not even thinking I grabbed Valvoline 10w-40 4 stroke synthetic motorcycle. I was running the Rottella 15w-40 but had been meaning to switch to synthetic and saw "4 stroke" and now feel like I probably made a mistake. 20w-50 was the only other option for synthetic motorcycle and it was late.
12-03-2018, 08:33 PM | #2 |
The W stands for winter viscosity. A 10W30 would have a winter viscosity of an SAE 10 oil and 30 when the engine warms up. Unless you plan to ride in sub freezing temps, a 10w40 or 15w40 oil will work well to 20 degrees, even colder if the bike is stored inside.
https://www.polytrondirect.com/infor...il-weight-oil/ |
12-03-2018, 09:47 PM | #3 | |
Hmm, it sounds like I do need a thinner oil then. Do they make a 5W-40? It’s been as low as 16f so far. 19f tonight. I do let the bike idle for 5-10 minutes in the mornings though. With winter just getting started it’s not bad yet, we’ll see 0f to -7f at some point. |
12-03-2018, 10:08 PM | #4 | |
5w30 is recommended by most manufacturers for those temps. If the engine cools while riding in cold air, a thicker oil can turn to sludge and not lubricate as well. This new card shows 10w and 15w going lower in the temp zone. You maybe OK. |
12-04-2018, 07:50 AM | #6 | |
Yeah it shows the 10W family going all the way down to zero so what I have in there now may be ok like you say. |
12-05-2018, 06:54 PM | #7 |
Rotella T6 works great in cold weather. The more fun part is getting your carb jetting adjusted for the cold weather.
