HiBird 250 sprockets
Stock gearing is 16 front and 46 back, which means gear ratio is 2.875. I want a gear ratio of 2.5 for highway, like JTF259.17 and JT269.43. Do y'all think a 17 up front would clear?
edit: The clearance between the 16-tooth with chain and the engine case is about 4mm. ![]()
Chinabikeless |
Couldn't tell without the chain on, but it looks like a 17 would be ok.
I have all of soberday to satur up!! |
Where can I find a JTF259.17? I've tried bikebandit, jcwhiteney, and denniskirk without luck.
Chinabikeless |
#5 | |
Chinabikeless |
You can call them and get a 17(more than likely). I had to call them and get a 43 tooth for the rear of my GY-5 because they didn't have it listed on the website.
The clearance between the 16-tooth sprocket with chain and the engine case is only about 4mm. If I install a 17-tooth, will I have to grind off some of the engine case?
Chinabikeless |
a 17 wont clear without grinding a lot but i put a 40t on the rear and dropped about 1000 rpms and it runs great.it will cruise at 80 on the factory speedo, about 70mph acsual. mine is all stock with a 110 main jet. im gutting the pipe, installind an crf250 silencer, a clamp on uni filter and jetting up to a 115. ill keep yall posted. 8)
The plastic pad on the swing-arm wears out quickly with stock sprockets (16 front, 46 rear). I'm afraid if I use smaller rear sprocket, the pad will wear out even faster.
Hey willy, is the Hibird rear sprocket the same as Lifan's?
Chinabikeless |
#10 |
i dont know dragon, i just called that eternal journey guy on here and he knew just what i needed and had a good bit of knowledge of the bikes. 8)
#11 |
hey dragon i just remembered he said if it had 4 bolts holding it to the hub they were the same. 8)
#12 |
Yep, its the same.
#13 |
I'm confused by the different posts about the front 520 sprocket size. Some say use jtf-328; other say use jtf-1324. The two are very similar, within 1mm. I took my countersprocket off my bike and measured it with my plastic ruler. I'm not skilled enough for it to know which sprocket is a better fit. To y'all Lifan guys out there, which is the better fit front sprocket, jtf-328 or jtf-1324?
Chinabikeless |
#14 |
The jtf 328 will not fit the lifan counter shaft. I found this out, but trying the one that came on the xr200r on the lifan engine.
So you need to use the 1324 one. I will be ordering one to let you know how it fits. Allen
