Old 01-19-2015, 06:33 PM   #1
TheGageinator   TheGageinator is offline
PZ30 vs Mikuni! Comparison with pictures
Here is a Comparison of the Mikuni 30mm clone and a KeiHin P30 30mm carburetor.
ID measurements
The PZ30 measures 30.48mm inlet and 38.1 outlet
Mikuni measures 30.353mm inlet and 39.37 outlet
Now some side by side shots. Mikuni on left, PZ30 on right.
The mikuni has 4 bowl screws the PZ30 has 3
The idle screws are different
This Mikuni came with a lever choke, the pz30 was cable choke. They are interchangeable between brands.
The Mikuni came with a nice coating of clear oil inside to keep everything in good shape. All edges smooth
The PZ30 had a lot of rough castings spots and extra metal hanging off in places. I also found metal shavings in numerous places. I have already corrected all these problems before the pictures. Sorry.
Inside of the PZ30
Jets are not labeled
Inside of the Mikuni
Labeled jets. Mine came with a 100main and 30 pilot jet
Old 01-19-2015, 07:42 PM   #2
guttafixit   guttafixit is offline
guttafixit's Avatar
Awesome write up. Glad you posted this because I was thinking about upgrading mine.
Thank you, Dan
Old 01-19-2015, 07:48 PM   #3
i would suggest the mikuni for sure. easier to tune and jet
