04-15-2008, 10:53 AM | #1 |
Is my tranny shot ?
Hello,
When I was changing my counter shaft sprocket, ( went from a 15 to 16 and have a 48 rear) I noticed I could rotate the shaft about a tooths worth or about 20-25 degrees. This seems like alot of slop in the gears. It didn't matter which gear it was in 1st thru 5th. I bought the bike used and it has 3600 miles on it. There is some gear type noise, not when coasting but when accelerating. I have a new chain and replaced the swingarm bolt. Could the transmission be worn out ? Thanks |
04-15-2008, 11:25 AM | #2 |
I am not sure about the amount, but being able to turn it some is normal.
That doesn't sound too bad. Allen
04-15-2008, 12:05 PM | #3 |
Nah, probably not. With those miles, I'm sure they all have some slop. Keep the oil changed regularly and it should be fine.
