08-17-2011, 07:39 PM | #1 |
zongshen 250 clutch
i have fried the clutch on my zongshen.
Need input as to where to get parts other than e-bay (nothing on there anyway)
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div> |
08-17-2011, 09:30 PM | #2 |
There's plenty on eBay. Here's a decent price, and you can have it shipped to Sumas to save some cash; that's what I do: Clutch Assembly
I had a quick look on the Gio site, but they don't seem to stock any right now. The only local shop I can think of is Saga.
08-17-2011, 11:06 PM | #3 |
ya that's the right assy but I would think that I can rebuild it no?
the oil definitely did not smell right and even a friend said fried clutch smell there were also lots of small bits of crud in there also will I have to make my own gasket for this casing? (not like it is a problem)
08-18-2011, 01:18 AM | #4 |
Sure you can rebuild it, but the entire assembly is likely a better value. You can get a replacement gasket or use a product like Three Bond or Loctite flange sealant.
This is a good time to point to the round cover to the right of the clutch, with three retaining screws and a spring in the middle. That's the cover for the oil pump pickup, and it's likely full of junk. Carefully remove the cover, and then dig out the sludge before putting things back together.
08-18-2011, 01:21 PM | #5 |
just waiting for a call back from that fellow in abbotsford off of craigs list....he advertises that he carries clutches and parts so see what he can do first. Weld...you might want this guys #.
08-18-2011, 01:53 PM | #6 |
wooohoooo he has the plates and they are $5.00 each. pick them up tomorrow.
08-18-2011, 05:31 PM | #7 |
went out and took the clutch apart and cleaned everything.
reverse is on the left and the smooth one on the right is first...well there's your problem. :roll: here is what was left behind after filtering the varsol through a rag
08-19-2011, 01:09 AM | #8 |
Was there sludge behind the oil pump pickup cover?
08-19-2011, 01:52 AM | #9 | |
08-19-2011, 02:34 AM | #10 |
another reason to crack the engine once a year, give it a good cleaning, change a few worn parts and toss it back together.
Its not like these are all that hard to rebuild too. I am going to make that part of my normal routine now. So I have to keep a spare set of gaskets, and a few other parts around, that might cost me a whole $50??
TCCK: The Coca-Cola Kid......... Hide your pepsi or I take your soul !! |
08-19-2011, 07:23 PM | #11 |
picked up the parts and gasket today ...... $40.00 total.
plates are soaking in oil now.
08-19-2011, 08:23 PM | #12 |
next question ....i have 5 disks and 4 spacers . do they go 4 in the long slots and 1 in the short slots or 3 in the long slots and 2 in the short slots?
from my pic (should have taken a better one) looks like 3 in long and 2 in short.
08-19-2011, 10:33 PM | #13 |
called the guy i bought them from and he says all in the same long slot.
going together tomorrow.
08-20-2011, 06:54 PM | #14 |
all back together and working better than ever.
after that was done and a few test rides down the alley....went on to fix a break in the plastics. drill the holes cut some mechanics wire bend into stitches insert and twist from behind thats enuff for today.... going riding tomorrow.
08-24-2011, 03:10 AM | #15 |
This is awesome, thanks for posting the pics. I'm guessing I'll be doing this kind of thing to my Beast in the near future...
