09-10-2010, 03:07 PM | #1 |
changing tires
how do you guys change your atv tires ?
would like to be able to do this myself but when i had my rear tire swapped out even the machine had a hard time doing it and it costs me 25 bucks per tire to have it changed |
09-10-2010, 03:16 PM | #2 |
I ask my buddy from the tire shop to do it. It took him about two minutes to install a tube in my quad rim, taking his time.
He is now a sales rep, but when he used to change tires, he won what's known as a tire rodeo. He was able to mount a car tire on a rim, seat the bead and inflate it to 32psi within 32 seconds. 8O Maybe I can convince him to let me film him changing a quad tire for the benefit of the forum. That should only cost a couple of beers.
09-10-2010, 04:26 PM | #3 | |
09-10-2010, 07:45 PM | #4 |
Give him the beers first. It needs to be entertaining too. :wink:
09-10-2010, 07:53 PM | #5 |
from watching videos on youtube it seems its just easier to pay to have it done.. other wise i need to buy a bead breaker, but with how little i ride and will rarely ever have to change tires it wont get much use..
09-11-2010, 12:35 AM | #6 |
I would also love to see the video, W&G.
Here is an inexpensive, ATV tire changer from Harbor Freight; it's even currently on sale! http://www.harborfreight.com/mini-ti...ger-34552.html If this ATV tire changer works, it will pay for itself very quickly, Mike. Here is a link to a nice thread describing how to use the Mini-tire changer. http://www.modernvespa.com/forum/topic10771 This item seems to get pretty good reviews. Spud
09-11-2010, 01:22 AM | #7 |
i am deff going to look into getting that !!!! thanks spud even if i dont get while its on sale at 55 bucks shipped its not to bad of a price
09-11-2010, 01:27 AM | #8 | |
09-11-2010, 01:36 AM | #9 |
i get their paper every time the send out a new one, but i think those coupons are for in store items only..
09-11-2010, 02:16 AM | #10 |
I have never changed an ATV tire, so I will gladly defer to others who have more experience. After reading a bit on this topic, I surmise one of the major problems is breaking the bead on an ATV tire. I don't know how well this Harbor Freight tool will perform. :? Incidentally, this Mini-tire changer is also sold by several other vendors.
http://www2.northerntool.com/auto-re...em-13473-1.htm http://www.gesusa.com/Ranger-RWS-2TC...r-p/132802.htm http://www.bendpak.com/shop-equipmen...t/RWS-2TC.aspx Some reviewers say this tool is too weak for changing ATV tires. :( I have read some people get the local Wal-Mart to mount their ATV tires for a modest price. This is certainly an interesting topic; I am interested to hear the opinions from the more experienced members of this forum. Spud
09-11-2010, 02:34 AM | #11 |
after looking at it more, it appears that because of the way atv wheels are... the center of the wheel is opened up and not just a small hole for the axle. you would have to pull the whole wheel/hub off and leave the hub mounted to the wheel..
im pondering making my own, ive got a metal fencing pole concreted into the ground.. drill a hole through it and use 2 peices of flat metal, bolt them slightly loosely to it, one on each side of the pole. then drill a hole in the flat bars say 1ft out from the center pole in the ground, then take another pole and drill a hole in that and bolt it to the flat bars. that should be roughly like the ones you see on hf and ebay. it should be fine for breaking the bead. ive seen people on youtube use a concrete parking space bumper placed on the tire about a inch from the wheel, then drive a truck up on it and it pops the bead quickly.. but my thing is actually taking the tire off. |
09-11-2010, 04:18 PM | #12 |
CHANGING TIRES
I deflate the tire.. ( remove valve if you want) then I break the bead on the rear of the rim first.. sometimes you have to put something under the rim so you can force it to break easier.. and it also helps to use some liquid soap to hel the bead to slip loose.. then do the front side.. remove the tire from the front side of the tire.. the rim lip is small that way... unless you have the larger ATV tires.. I do this all the time.. takes maybe about 2-10 minutes.. depends how it goes.. this saves $$$ you can practice on the small tires until you get the nack of doing it
