08-01-2018, 02:29 PM | #1 |
Magician 250 starter
Anyone have any issues with the starter continuing to run after starting? I have had this happen a few times, and am unsure how to determine if it is the solenoid sticking or the wiring. I have taken apart the push button and followed the wires down, and I don't see any obvious problems. Should I replace the solenoid? Are there better ways to test to ensure that the solenoid is the problem? I can't replicate the problem at will, so it is tough to get a multimeter or something in place when it happens to check. So far, I've rushed to disconnect the battery when it happened so that I don't burn out the starter.
08-01-2018, 04:29 PM | #2 |
I would start by cleaning the starter button contacts on the bars. If that fails, I would replace the starter relay. They are around $10 the last time I saw one.
08-02-2018, 11:02 AM | #4 |
Remove whatever you need to in order to easily access the solenoid. When the symptom occurs, unplug the small two-wire connector at the solenoid and see if the starter stops. If it does not, the solenoid needs to be replaced.
08-02-2018, 12:36 PM | #5 |
Thanks, I'll give that another look. The button setup is pretty finicky, so I could easily see that being a problem. I may look into a better button to replace it if that is the problem. Where did you see these relays for sale? I was just going to replace it with something similar from the auto parts store if necessary.
08-02-2018, 12:38 PM | #6 | |
08-03-2018, 11:31 AM | #7 |
That's the beauty of brainstorming. When you have questions, don't be shy about asking them here; several members love to help.
08-03-2018, 06:40 PM | #8 | |
And if it dose stop the start button is the issue... ..
