Old 07-17-2018, 04:52 PM   #1
slowroller   slowroller is offline
Clutch basket play
Im chasing a problem with shifting. I pulled right cover and from what i can tell everything working as needed. When i was shifting i could see clutch basket moving alot. Anyone have trouble with then loose or are they suppose to float. Are they bushing or bearing style. What is torque on them?
Old 07-18-2018, 01:06 AM   #2
pete   pete is offline
pete's Avatar
is the basket rivited to the back gear or is there a cushing unit....
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 07-18-2018, 03:11 PM   #3
Im not sure at this point id say solid be weekend before my socket comes in to disassemble it. I was hoping the hawk masters were going to chime in. If not ill keep ordering parts till i fix it.
Old 07-18-2018, 03:59 PM   #4
To be honest, it isnt much to go off of. This is one of those situations where a video of what you are describing would say a lot more.
Also, iirc, these use a bushing instead of a roller bearing.
Old 07-18-2018, 05:10 PM   #5
Kivi   Kivi is offline
There must be a play in clutch basket, if the engine design of your bike is similar to mine. Please, make a video of the play. My clutch has a lot of play.
Old 07-19-2018, 01:46 AM   #6
pete's Avatar
sounds like yours needs looking at aswell...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 07-19-2018, 09:08 AM   #7
ben2go   ben2go is offline
The shaft bearing behind the clutch could be going bad.
Old 07-20-2018, 09:13 PM   #8
pete's Avatar
Is the play rotatonal or side to side "wobble"...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 07-26-2018, 12:17 AM   #9
NzBrakelathes's Avatar
Too many possibilities - Video please
The basket can wear on the spline too, or bearing or... or ......
Old 07-26-2018, 01:46 AM   #10
pete's Avatar
the basket is not splined to the shaft... the hub is...
the basket usaly runs on a bronze bush as it only rotates free of
the hub if the clutch pulled in... at any other time the basket and
hub rotate as one unit as they are connected by the clutch plates
and springs...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 07-26-2018, 08:22 PM   #11
Thanks for all the help im try to replace all parts and inspect wear and report back if any of that helps.
