Old 07-14-2018, 01:50 AM   #1
ectomite   ectomite is offline
centrifugal oil filter hawk 250
Hey, guys got a problem my centrifugal oil filter fell off inside the engine. so now the end of the crankshaft threads are messed up I'm trying to find out what size the nut is that goes on the end of the crankshaft that holds the centrifugal oil filter on where I can get the right die to rethread. I can't find much info and what I got is confusing. I brought the nut to a local machine shop they measured 15mm on the inside. So I called ricky power sports and they said it's 16mm so I don't know. I will attach some pics if anyone knows I would greatly appreciate the help and thanks ahead of time.
Old 07-14-2018, 02:17 AM   #2
If the machine shop measured the inside diameter of the nut, then they didn't account for the depth of the threads cut into it. Metric thread sizes are based on the shank size of the bolt (crank in this case), so if if inside of the nut is 15mm, and the threads are .5mm deep on the crankshaft, this would make the nut an M16 (not a very good machine shop if they don't know this).
If you have a pair of vernier calipers (you can get some digital ones cheap at harbor freight) then you can measure the O.D. of those threads on the crankshaft. Obviously your reading won't be precise since the threads are damaged, but if it reads something like 15.8, just round up to 16.
So if we know it is an M16, then to get the thread pitch you will need to measure the distance between the thread peaks in a straight line on the crank shaft. If they are 1mm apart, then it is M16x1.0, If they are 1.5mm apart, they are M16x1.5, and so on. You can use those same calipers to approximate this distance as well. This link can possibly explain it better. https://www.boltdepot.com/fastener-i...iandpitch.aspx
If I had to guess by visual, then I would say it is an M16x1.5, but I would measure to know for sure.
It is unusual for this type of failure to happen, so the only thing I can assume is somebody at the engine factory installed the bevelled washer in backwards. The washer should have a stamp on it stating which direction is out. If it is installed backwards, there is potential for the nut to back off. example: https://www.cscmotorcycles.com/fckim...acement/28.jpg
Old 07-14-2018, 02:21 AM   #3
pete   pete is offline
pete's Avatar
thread gauge will give you the tpi of the thread...
look like a small pack of saws... simular to feeler gauges...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 07-14-2018, 02:28 AM   #4
This also works if you can locate one locally.
example. https://www.lowes.com/pd/IRWIN-Metri...4aAoDaEALw_wcB
One of these can also be used, and is quite handy to keep around. https://www.ebay.com/itm/Screw-Bolt-...4383.l4275.c10
Old 07-15-2018, 02:04 PM   #5
Hey, thanks megadan and Pete u guys were very helpful I picked up the tools mentioned seems its a 16mm 1.0 thread depth. only thing now not sure to get a right or left tap to cut the threads. And ya Meagan I heard this is an unusual failer not sure witch way that washer was installed since everything was free floating. I tell ya I have had nothing but bad luck with this bike so far from dealing with the texas power sports crap and engine problems now can get a little frustrating.
Old 07-15-2018, 02:40 PM   #6
Looks like right hand threads to me. Standard Righty Tighty.
Old 07-15-2018, 04:19 PM   #7
Okay, thanks megadan looks like I'm good got the tap ordered appreciate the help from you guys.
Old 07-15-2018, 05:15 PM   #8
No problem, it is what this forum is about. Once you get everything sorted out you will be able to enjoy the bike. Stick with it!
Old 07-17-2018, 01:23 PM   #9
Sullybiker's Avatar
CSC state 60ft.lb of torque on that nut. I used an aluminum washer between the primary gears to lock them. It's not easy to tighten it otherwise.
Old 07-28-2018, 11:59 PM   #10
Wow did not know it was 60ft.lb. it does look hard to tighten wonder if I could just use my impact gun on it if I was carefull.
Old 07-29-2018, 02:11 AM   #11
You could also thread some small rope through the park plug hole and turn the engine by and until it stops the piston in place to hold the crank still. Obviously, make sure the rope can be pulled back out lol. Also a handy trick to hold up valves if you want to change the valve stem seals without pulling the head.
Old 07-29-2018, 10:12 PM   #12
Thanks megadan for the tips very usefull information. I just stuck a penny between the gears I was in a hurry to get going again seemed to work so there is another way to stop the crank for future reference for everyone.
