Old 03-20-2020, 09:01 AM   #1
Rocket tests   Rocket tests is offline
Rocket tests's Avatar
TBR7 flappy front fender?
I've been enjoying my new TBR7 as much as is possible while confined to my own land. One of the things which I find to be a bit of a distraction while riding has been the flappy front fender. I've pretty much decided that I'm going to fabricate a support bracket from some 1/4" UHMWPE sheeting I have laying around, just something to sandwich between the mounting bolts and underside of the fender. I would like to maintain some degree of flexability for obvious reasons.
Before I start on this project I figured I'd ask the forum if anyone else tackled this issue and if so, how?
Old 03-20-2020, 09:36 AM   #2
I can confirm its "flappy" alright.
I considered dremmeling mine to make it a bit shorter and lessen the flap, alas it does not distract me enough so I left it
Old 03-20-2020, 03:02 PM   #3
Kenstogie   Kenstogie is offline
Kenstogie's Avatar
I put rubber washers between bolt and fender but I don't know if did anything as I have not ridden it yet! I am hoping to get the weekend off though....
been around bikes for a while....
honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7
all about the Tao MotorsTBR7
http://www.chinariders.net/showthread.php?t=25553
Old 03-20-2020, 03:15 PM   #4
I did the same Stogie. I figured that overtightening the fender bolts would do nothing to maintain the structural integrity of the fender nor would it prevent the screws from possibly backing out. I figured that the rubber compression would be a good method to prevent screws from backing out without the use of lock tight. I may still use the locktight after I get the headlight adjusted where I want it.
Old 03-20-2020, 03:54 PM   #5
It needs more of a "spine" of sorts to stiffen up
Old 03-20-2020, 04:25 PM   #6
Wild Dog   Wild Dog is offline
There are flappy version and some version that more rigid. Flappy are better if you are doing some off road, it falls it won't break.
I had a rigid version on mine, it broke on the first fall.
Old 03-20-2020, 05:04 PM   #7
I think the fender is much better now. I drilled out the main jet using a torch tip cleaner, no idea what it is now(one size up on the tip index). It runs much smoother now, far less floppyness��.
The low speed jet still needs done, it sometimes shuts off when I nail it from idle. There's no store open to get the proper jets so I'm awaiting a jet kit ordered from ebay. I can try adjusting the low speed mix screw but I'd rather just use the correct parts if I can.
I'll wait to see how floppy the fender is once it's tuned properly before I try modifications to the fender.
