04-05-2021, 11:02 PM | #1 |
Kick stand soft ground shoe, or pad ?
I have found myself in the spot a few times now were my kickstand want to sink in the mud, and I have to either push the bike around checking for better ground ,or find something to put under the kickstand. Every time I experience this, I intend to pack something on the bike for this scenario, but I always forget to do it. It happened again today, in more of a sandy soil, rather than muddy, and I actually resorted to using my wallet. I am just curious what you folks pack on your bike to keep the kick stand from sinking in soft ground. I am thinking of rounding up an old flip flop sandal, and cutting a pad from it.
04-05-2021, 11:34 PM | #2 |
Something like a kickstand pad should work out.
https://www.amazon.com/KiWAV-Motorcy.../dp/B00CPGQ1GO
NO HILL TOO STEEP NO MUD TOO DEEP The Brozz | The Hawk Upgrades, Accessories, Etc... Assembly Checklist: Brozz 250 | Hawk 250 ~idle_purr |
04-05-2021, 11:43 PM | #3 | |
04-05-2021, 11:50 PM | #4 |
ebay for .99 Link Here minimum order of a thousand... j/k
Off topic but are you an actual Hillbilly? You could use a crushed cigarette box lol.
04-06-2021, 01:20 AM | #6 |
Flattened beer/soda can.
04-06-2021, 04:17 AM | #8 |
Ohhh, fancy!
On a more serious note, I have considered simply welding a well shaped bit of flat steel to my kickstand foot just to have something wider already attached. One of those bolt on style ones would be nicer, obviously. I wonder if there is one out there that would work.
04-08-2021, 08:15 AM | #11 |
I did make a few from the sheet of whatever kind of material that thin panel on the bottom of the crate is made from. It is very strong, thin, and lightweight . Once I started thinking about it ,I saw potential in all sorts of things. I just settled on the crate panel because it will take up next to no space.
