Old 07-25-2016, 05:48 PM   #1
Motohead   Motohead is offline
2005 NewStar 250
I have purchased a 2005 newstar ATV 250cc water cooled and am looking for parts it appears to have at least a blown head gasket seeing exhaust coming out from water inlet pipe and milkey oil I am looking for head gaskets possabibly a whole new head, piston, ring, cylinder assembly any one know a source for parts for this thing
Old 07-25-2016, 08:07 PM   #2
humanbeing's Avatar
Any pictures of that engine? What's the maker (The WMI ie. letters 1-3 of ViN ) / stamped cc & model http://www.mychinamoto.com/forums/sh...identification ... ?
Old 07-25-2016, 09:05 PM   #3
Here are some photos numbers under the shifter are: 171FMM and *05A720526*
VIN starts with LHJ
Old 07-25-2016, 09:31 PM   #4
Im having trouble with that site. I have registered but never received an activation e-mail checked my spam folder as well i can log in but cant download any attachments or post yet
Old 07-25-2016, 10:59 PM   #5
humanbeing's Avatar
LHJ = Bashan
Something weird in there. The barrel don't looks like typical water-cooled CG250 ...
71 What's that? The most common water cooled uses 67/69/70 (16mm pin) piston ...
F = Air-cooled in theory
Old 07-26-2016, 07:46 PM   #6
LHJ = Bashan
the ones ive seen for sale dont have any fins on them
171FMM that's the number
Figures I would get some kind of oddball.
any ideas on where to find parts
Old 07-26-2016, 10:46 PM   #7
humanbeing's Avatar
As u said it's some oddball
171FMM maybe a lie... Measure it 1st. Barrel: height * width as http://www.mtctg.com/category.php?cid=5 | Piston: the Ø, pin Ø , compression height
If matches a common 16mm pin model, u're saved from hellhole ...
Old 07-27-2016, 11:39 AM   #8
Thanks for your help I'll take it apart and measure
Old 08-04-2016, 12:56 AM   #9
got it apart
Here is a photo with measurements the bottom left head bolt was not even finger tight causing the failure problem is the measurements everything I'm finding is 67mm
Old 08-04-2016, 04:17 AM   #10
Darth Racer's Avatar
If you can't find the gasket you might have to go the route of a universal sheet gasket you cut to match. Metal shimstock possibly.. Not sure on this one.
Old 08-04-2016, 11:00 AM   #11
Yea its a 3 layer MLS gasket
Old 08-04-2016, 11:07 AM   #12
humanbeing's Avatar
67mm water-cooled CG250 had 2 main types:
Lifan http://item.taobao.com/item.htm?id=524011100285 / Zongshen: http://item.taobao.com/item.htm?id=523998146869
Old 08-04-2016, 05:52 PM   #13
Good find
Old 08-04-2016, 05:59 PM   #14
If it helps any ....
https://translate.google.com/transla...romSite%3Dmain
and
https://translate.google.com/transla...3D523998146869
Old 08-07-2016, 01:38 PM   #15
Maybe I measured it wrong but I came up with 64 mm bore. I'm out of town now i'll check it again when I get back.
