04-15-2023, 03:05 PM | #1 |
Shift Indicator Not Working Magician
My shift inidcaor does no work. However, when I turn on the left blinker, a small flashing light appears in the indicator window. I think the arrow in the indicator should blink instead.
I've gone thouigh the wiring and can't seem to find anything amiss. \ Any help is greatly appreaciated. Vince |
04-24-2023, 01:00 PM | #2 |
This problem seems to have stumped everyone
04-24-2023, 01:30 PM | #3 |
Hate to say it, but there ain't much for us to solve. 90% of this is going to need to be found on the bike. A multimeter and some testing.
04-24-2023, 03:20 PM | #4 |
You might check to verify that the bus connector (probably a sixpack, white plastic connector). The bundle of wires usually comes from above or in front of the front sprocket cover. They are probably in a black plastic tube. This connector typically comes with the engine, has maybe a 12 to 20inch length with the plastic connector at the end. It should connect to the wiring harness about where the carb is, or above.
05-07-2023, 09:37 PM | #5 |
Thanks I'll chcek that out
Tags |
indicator, shift indicator |
