Old 06-21-2020, 03:28 PM   #1
Lplp60   Lplp60 is offline
Bull 200 rear axle ,broken or just shifted loose
Brand new but never used 2 bull 200 atvs ,1 hour of use in 2 years ,took them out this weekend and the axle either loosened or broke ,thoughts on this ,easy fix etc .
Old 06-21-2020, 04:49 PM   #2
Mudflap   Mudflap is offline
Jam nuts next to the brake disk came loose. 5 min fix.
Old 06-22-2020, 05:54 PM   #3
Not sure what you mean jam but, I called for the part where I bought it and they said it is all one part ,they said it snapped in half .
Old 06-22-2020, 06:49 PM   #4
Put a block under the center to raise the wheels. Push in on right hand wheel until the axle splines are inside the sprocket. May have to wiggle the sprocket and disk. Snug up the big nut next to the disk and tighten the other nut against it.
Old 06-22-2020, 06:59 PM   #5
Oddball Matt   Oddball Matt is offline
The construction seem mirrored albeit otherwise similar to what I have, please read through this link and see if you can draw any wisdom out of it.
http://www.chinariders.net/showthread.php?t=25183
2004 Longjia Grido 50 scooter
1999 Cagiva Mito 125 Evo, Yamaha XV125 engine, Ducati SS fairings, getting turboed
1993 Yamaha GTS 1000
Ex:Bashan BS200-S7 `07 Streetfighter-quad
