10-14-2020, 07:40 AM | #3 |
Welcome aboard! Nice to see they are doing some upgrades.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 10-14-2020 at 01:27 PM. |
10-14-2020, 01:25 PM | #4 |
I would love to upload some pictures but unfortunately that is way above my pay scale. Sorry.
10-16-2020, 12:56 PM | #6 |
It also has an led headlight.
10-17-2020, 01:29 PM | #7 |
What dealer did you get it from?
10-17-2020, 01:40 PM | #8 |
Txpowersports
10-17-2020, 01:45 PM | #9 |
I think I figured it out. Here should be a picture of the turn signal.
10-17-2020, 06:35 PM | #10 |
It also has a 12t front sprocket
10-17-2020, 06:36 PM | #11 |
It has a 12t front sprocket
10-17-2020, 08:05 PM | #12 |
so it's lower geared than the 2020, which is 15/46. I run 17/40 on mine which gives me 10mph/1000rpm in top
10-17-2020, 09:01 PM | #13 |
I’m new to all of this. Unfortunately I haven’t been able to ride it yet. What difference would there be between our setups?
10-18-2020, 05:12 PM | #14 |
There doesn’t appear to be too much room for a bigger front sprocket. I’ll be lucky to get a 13 in there. My question is can I go too small for a rear sprocket? If I get a 13 on the front could I just put a 30 or 32 tooth rear to get where you are with your 17-40?
10-18-2020, 07:05 PM | #15 |
you might be able to, I'm not sure what the smallest rear sprocket is. I'm able to run those sizes because I've done a lot of engine mods to get the power to do so. You say there's not much room for a larger front sprocket? I wonder if there's been a re-design to the motor cases in that area or is the chain bigger? Also why doesn't the quote feature work when replying?
