Old 01-31-2007, 02:58 PM   #1
msRandi   msRandi is offline
Send a message via AIM to msRandi
Help
time for first real oil change . So here is queston were is the oil filter or what pass as a filter?We have ohv 200 motor
thank you & love from the big island[/b]
Old 01-31-2007, 03:01 PM   #2
Roketarider   Roketarider is offline
Take off the oil cap and there will be a small mesh drainer thing right inside there. To my knowledge, no oil filter like a car or anything, but don't quote me.
Roketa DB-07A 200cc
Old 01-31-2007, 03:17 PM   #3
red2003   red2003 is offline
Pull the oil drain plug (big chrome nut on bottom left side of engine, near the shifter). Behind that is a spring that will more then likely fall out. That spring holds in a cone shaped screen. Remove the screen, flush it out, reinstall screen, spring, nut. Fill with 1 quart of oil. Fire it up and drive!
Old 01-31-2007, 03:21 PM   #4
thank you
Thanks for the help. I feel better now.
Old 01-31-2007, 03:52 PM   #5
PolygonFla   PolygonFla is offline
If you need some pics there were some post here a while ago.
http://www.chinariders.net/modules.p...ght=oil+screen
Old 01-31-2007, 07:01 PM   #6
oil
Thank you all. I put new oil in the 2 bikes befor we ever road them.But pulled the bottom plug and never looked at the other plug/ filter.
Old 01-31-2007, 10:17 PM   #7
got it done!!!!!!!!!!!!!!!
Well did the first service on the two bikes, Oil, valve ajust, welded up every thing we broke. and set to start all over againe.
