05-01-2010, 12:38 PM | #1 |
How to install an electronic tachometer on a CDI ignition
How to install an electronic tachometer on a two cylinder, four stroke engine with CDI ignition.
I received my electronic tachometer yesterday and went to install it and realized that I had two coils instead of one. I tried hooking it up to one of the coils but that didn't work. I was ready to give up when I decided to do a little research on bikes with a tachometer hooked up to a CDI ignition with two coils. You ether had to have a CDI with a tachometer terminal built in or buy an adapter to hook both coils up to the one tachometer input. I didn't have ether one. The adapters run about $30 + shipping. Then you have to wait several days or more for it to arrive in the mail. So, I said the heck with that and made my own for free. The parts cost about a $1.00 at Radio Shack but I already had them in my parts bins. It takes two 100k ohm resistors and two 1N4007 diodes. The diodes keep the current from flowing back to the other coil and the resistors smooth out the signal and keep the tachometer needle from bouncing. Thats it. Here is the schematic. |
05-01-2010, 01:13 PM | #2 |
Will that work on a single cylinder Chinabike?
Happy to serve. |
05-01-2010, 02:24 PM | #3 | |
There are also tachometers that just wrap a sensor wire around the spark plug wire to receive signals. This one has a graphic tach & lots of other options like programmable indicator lights, speedometer, cyl/water temp, signals ... http://trailtech.net/computers.html Also available on ebay. I almost bought one of these but I didn't think it would look too good on a cruiser. Plus its a bit out of my budget. :wink: |
05-01-2010, 03:42 PM | #4 |
Excellent report! What did you use to house the diodes and resistors?
05-01-2010, 04:15 PM | #5 | |
05-01-2010, 06:01 PM | #6 |
I thought about a pc board but didn't want to waist one. Actually I just paired them up and twisted the ends together and soldered 18ga wire ends on them w/connectors. I then shrink tubbed them individually and then shrink tubbed them as one unit. The end result is a "Y" shaped wire assembly that has a bulge in the middle. Fit neatly under your tank near your coils.
05-07-2010, 03:21 AM | #7 |
That is a very nice job, TD! Thank you for the excellent writeup.
02-02-2017, 04:06 PM | #8 |
CDI tach adaptor
First of all, sorry for digging up an old thread. But is there any chance you still have the diagram for how you did this? And if not I was hoping you could draw another one up, I am trying to put a modern digital tach on a motorcycle with cdi ignition.
Thank you. Ryan |
02-02-2017, 07:10 PM | #9 |
tdkrantz's bike is based from mid-90s JDM Rebel CA250. Don't know how's CX wired BUT https://item.taobao.com/item.htm?id=536139476392 pretty useful (had different Hz settings) .
The signal can grab from anywhere btw pulser & H.T. coil's input [H.t coil in/ CDi out / CDi pulse in / pulser out ] Find the suitable point urself, somewhere that had the least eletctrical interference ...
06-21-2018, 08:49 AM | #10 | |
help
06-21-2018, 12:04 PM | #11 |
The diagram was posted in 2010 and the original hosing site may be gone. That's why it's always best to upload pics directly to the forum.
05-05-2019, 01:48 PM | #13 |
Dual Coil Tach Hook-Up
I'm back ... 9 yrs later.
Here's the diagram: |
05-06-2019, 06:39 AM | #14 |
Y’all still have an open radio shack? That’s awesome
